Unconfigures the RADIUS accounting server configuration.
| mgmt-access | Specifies the switch management RADIUS accounting server. |
| netlogin | Specifies the network login RADIUS accounting server. |
| primary | Unconfigures the primary RADIUS accounting server. |
| secondary | Unconfigures the secondary RADIUS accounting server. |
Unconfigures both the primary and secondary accounting servers for management and network login.
If you do not specify any keywords, this command unconfigures both the primary and secondary accounting servers for management and network login.
mgmt-access—Use this keyword to unconfigure only the accounting server(s) for management functions.
netlogin—Use this keyword to unconfigure only the accounting server(s) for network login.
primary—Use this keyword to specify only the primary RADIUS accounting sever.
secondary—Use this keyword to specify only the secondary RADIUS accounting server.
The following command unconfigures the secondary RADIUS accounting server settings for both management and network login:
unconfigure radius-accounting server secondary
The following command unconfigures the secondary RADIUS accounting server settings for only network login:
unconfigure radius-accounting netlogin server secondary
The following command unconfigures all RADIUS accounting server settings for only management functions:
unconfigure radius-accounting mgmt-access
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
